mediumchung
- Mazda 5 2.0 2006
Hello, I own a 2006 Mazda5 2.0 and the problem came since last week.
The engine shock slightly during idle when A/C was off, and shock like going to stall when the A/C was on.
When I pressed on the pedal the vibration simply gone. It ran smooth like usual but gas consumption increased by 1/4.
The RPM at idle was normal at around 700 - 800 when the engine shock. The check engine light was not on.
I have replaced all 4 spark plugs, replaced a faulty ignition coil, oil changed and cleaned the throttle body just 3 months ago.
I believed that the A/C compressor didn't run smooth so I replaced it today, but didn't work.
Could anyone give me a direction on what to do with this?
Many thanks.
Many thanks.
