engine question
yea but will i have to change anything because my motor is gone it is seized and if they pull this out will the be able just to drop this one in
well the MSP engine I beleive has a couple more vaccum lines and what not. So everything will hook up but you might have some extras lying around on the MSP engine. You can however just use the MSP bottom end as long as none of your valves were bent.
wouldnt u need to rewire anything to get it to work? like the ecu is different from mp3 i no that for sure, but will it need rewiring for it to work on a mp3 body?
yea i did call you but i found wat i needed..i got a full msp setup a complete change over for 2600 shipped to my mechanic
You will be an MSP ecu or standalone. As well all the IC piping and IC, or go to a FMIC. Not sure about the fuel system on the MSP vs MP3, but most turbo cars run a fuel return line and most n/a cars don't, if this is the case here then you will need a fuel return line.
