engine part out
Hello everyone, i'm parting out my old engine from my 2003.5 MSP that has 127k miles on it. I couldn't figure out why it was smoking so I just pulled it and dropped in a motor with less mileage. Had perfect compression and leak down test and found out after I pulled it that the exhaust valves were the problem. I put new Viton valve stem seals in and didn't help a while back so I assume the valve guides need machine work.
FS-DE block
FS9 cylinder head (exhaust valves leak oil, needs machine work. see pic)
Intake cam-[SOLD]
Exhaust cam-[SOLD]
crank shield cover (from N/A motor)
oil pan
oil pick up tube
harmonic balancer
ac compressor mounting bracket
valve cover
egr
clipped wiring harness (will separate certain pigtail connectors if needed)
flywheel
fuel rail and injectors
coil packs and plug wires
thermostat x2
coolant pipes
oil dipstick and tube (dipstick has broke handle, see pic)
water pump pulley
pcv valve with hoses
oem radiator cap
engine to trans plate
intake manifold
intake manifold to block brace
knock sensor
crank sensor
cam sensor
I'm open to any and all offers within reason. buyer pays shipping.
