shortyhawaii1
OK, I have searched and read all the posts relating to engine noise. I wonder if there is something else that I am missing. My mids/highs are whinning and the amp has an OUTSTANDING ground connection. RCA's are run on opposite side of the car, still using stock deck. One thing though. I have and EQ and I know the ground connection will play a role in noise, but I wonder if I just need thicker ground wire or a better connection? The wire I'm using for power and ground is the same gauge as the remote wire. It doesn't need that thick of power wire to run it, but I'm wondering if the ground wire should be thicker to reduce niose.
