Sway Bar Bushing Replacement How To
In order to install sway bar bushings, you'll have to either cut the old ones off if they have no slot, or unbolt the rear sway at the end link. Either way, it's pretty simple of an operation. This is a general how-to, so I'm not sure if it applies to the Protege completely, but here's a basic run down:
1.) Jack the rear of the car up, support with jack stands, and try and make sure the suspension is unloaded. Sway bars shouldn't shift too much if it is, but best to be sure, and all.
2.) Find the two bushings, which should be pretty simple to find. I like to take a minute to take out a silver Sharpie (Shows up on black!), and mark off where the two bushings sit, just in case.
3.) Unbolt either bolt on the first bushing, remove the bracket, if it's not attached, and find out if the bushing is slit or not. If it is, simply spray some WD-40 or silicon grease, and slide it right off of the bar.
3a.) If it is attached, decide if it's worth keeping, and is in good enough shape to put back on, if anything else fails. Cut it, if you wish, or go to either end of the sway bar, and unbolt it from the end links, and get out a can of WD-40/grease, and make sure the bar is slippery, then work it off the bar. Note, if you unbolt it from the end links, it will not be supported by anything, so be prepared to catch it.
4.) Energy Suspension bushings have a generic bracket, and it will need to be bent to fit. Just take it slow, with a pair of pliers or a vice, and reshape it as needed. Once you've done this, take the bushing itself, and find the slit which resides at the top of the bushing. Slide the bushing up around the bar in the correct location, and repeat on the other side. An extra application of grease wouldn't hurt right about now, and will keep the creaking to a minimum.
5.) Position the bracket over the bushing, and bolt it into place using the stock bolts, and torque to specifications. 32 to 44 ft-lbs per bolt, for both the bushing bolts, and the end link bolts. After this, rotate the bar, and bolt on the end links, if you need to, and you should be done. Grease the bushing up with a grease gun and fitting, or bring it to a shop to do so, if you feel like it, and make sure you grease it once per month or two, which should be ample, I'd imagine, as long as you use decent quality grease.
I hope that helps! If you want, I'll post scans from the FSM of the rear sway bar section for illustration, if you'd like.
- Eddie
