goldwing2000
Mazdas247 OG
- 2018 Mazda6
2004 Mazda3 (sold)
2024 CX-5 (sold)
Gbourdon said:Alignment is much cheaper than tires.
True, true...
goldwing2000 said:Bad shocks (they're actually struts) on a brand new car???
Ummm... ok. (scratch) (boom03)
Seriously though they are different lengths... maybe not enough to be visible in the pic you sent but DEFINITELY enough to throw toe off one side by 1/16" and the other by 1/8". 1/8" is a huge difference.goldwing2000 said:Nice... (boom07)
Gbourdon said:Get an alignment. I waited 2 weeks to get mine done and totally wore my tires quite excessively. Car drove straight as hell and handled fine but my toe was not even close. It was off by different amounts left and right but this may have been the case prior to the spring install.
stingfish said:Seriously though they are different lengths... maybe not enough to be visible in the pic you sent but DEFINITELY enough to throw toe off one side by 1/16" and the other by 1/8". 1/8" is a huge difference.
stingfish said:Thank you GBourdon!
Goldwing2000... I rest my case... I'll leave you alone now... no hard feelings here. (cheers)
stingfish said:Toe out is typically used in rear wheel drive cars... toe in is typically used in front drive cars... at least when we're talking performance driving on a track... your front drive car being 1/16" toe out each side will be 1/8" or more each side when it's driving down the road... not good. You're correct, toe out will make a car more stable, but this is a front drive car so it pushes through the turns if anything...
A rear-wheel drive vehicle "pushes" the front axle's tires as they roll along the road. Tire rolling resistance causes a little drag resulting in rearward movement of the suspension arms against their bushings. Because of this, most rear-wheel drive vehicles use some positive toe-in to compensate for the movement, enabling the tires to run parallel to each other at speed.
Conversely, a front-wheel drive vehicle "pulls" the vehicle through the front axle, resulting in forward movement of the suspension arms against their bushings. Therefore most front-wheel drive vehicles use some negative toe-out to compensate for the movement, again enabling the tires to run parallel to each other at speed.
goldwing2000 said:I just re-read your post... you got it completely backwards. Read the Tire Rack write-up again.
If you're going to try to school somebody, make sure you are presenting the proper information.
stingfish said:God dude... (braindead... well now I know you don't know what you're talking about... negative toe out is toe in - same freakin thing... and positive toe in is toe out. Give it up already. And if you don't believe me, go take an ASE course in alignments.
goldwing2000 said:Dude... what the hell are you talking about?? You just said "toe out is toe in" and "toe in is toe out"!! That make no sense whatsoever! It's like saying right is left and left is right.
An axle is said to have positive toe-in when imaginary lines running through the centerlines of the tires intersect in front of the vehicle and have negative toe-out when they diverge.
And I have my ASE certification in front ends and suspension, thankyouverymuch.
Like I said before, stop trying to sound like you know what you're talking about!
Look, I'm a motor guy. The way I have always understood it was as GW has layed it out. I'm alittle confused as to NEGATIVE and POSITIVE toe....I always thought it was just IN or OUT.?. (bang)stingfish said:I will repeat myself... in the world of performance suspension tuning...
toe in = toe in
toe out = toe out
NEGATIVE toe in = toe out
POSITIVE toe out = toe in
I am done with this tread... turning notification off.
OIC, that makes perfect sense. What was up w/ the (enguard). He was very defensive. Maybe not held enough as a child? J/Kgoldwing2000 said:"Positive toe" is toe in.
"Negative toe" is toe out.
Loose said:OIC, that makes perfect sense. What was up w/ the (enguard). He was very defensive. Maybe not held enough as a child? J/K
Above + earlier diagram =stingfish said:God dude... (braindead... well now I know you don't know what you're talking about... negative toe out is toe in - same freakin thing... and positive toe in is toe out. Give it up already. And if you don't believe me, go take an ASE course in alignments.
stingfish said:i have no clue who these guys are but it's the first thing that came up... it's there in black and white... 2nd section... Wheel Alignment 19.95? 3rd Sentence.
Toe-in means that the fronts of the tires are closer to each other than the rears. Toe-out is just the opposite.
Toe - The distance between the front of the wheels compared with the back of the wheels
Toe-In - Wheels are closer together at the front than at the rear
Toe-Out - Wheels are further apart at the front than at the rear
If the front of the tires points toward the centerline of the vehicle, with both tires aiming inboard, this is called "toe-in," because the tires on that axle are aiming inboard. If the front of the tires aim in an outboard direction, away from the centerline of the vehicle, this is referred to as "toe-out."
Toe-in is the measurement in fractions of an inch, millimeters or
decimal of degrees that the tires are closer together in the front than they are in the back. Toe-out is the same measurement, except the tires are further apart in the front than in the rear.
Toe-In is when the front of the wheels are closer together than the rear of the wheels on the same axle. Toe-Out is when the front of the wheels are farther apart than the rear of the wheels on the same axle.
Toe in is recorded as positive toe angle and toe out is negative.
Toe-in, or positive toe, is defined as the front of the tires being closer together than the rear of the tires. Toe-out, or negative toe, is when the rear of the tires are closer together than the front of the tires.
toe-out, aka negative toe-in
If the string is not in contact with the sidewall at the rear of the front tire, then that tire has negative toe-in.
Negative toe-in, also called "toe out", means that the front of the wheel points outward
