slavrenz,
Don't feel too bad. After buying the car at 90,000 Miles from a Coworker, I've replaced Radiator, EGR & now the Oil Pan Gasket needs to be replaced, which I'm told is a very Labor Intensive job on my Car. I'm now at 115,000 Miles.
Dino1956
Dino, by know means am I trying to show you up
(this would be like the worst possible topic to have a competition on), but this is what I've had to do to my car:
- 2 ignition coils: both went out 150 miles apart
- 2 pre-cats: one ruined by first coil going bad, next one ruined by second coil (1 day after warranty on the first expired)
- 2 motor mounts (front & back were torn)
- 2 front struts (started leaking oil)
- 2 front sway bar endlinks
- 1 front CV axle assembly (torn boot caused joint to fail)
- 1 front control arm (torn ball joint boot caused joint to fail)
- 3 O2 sensors (2 went bad from ignition coils, 1 heater circuit broke)
- 2 front wheel bearings
- 1 valve cover gasket & PCV valve (valve got clogged, leaked oil all over engine).
- 2 broken wheel studs (asshole before me crossthreaded the lug nuts)
- 2 rear sway bar bushings
- 1 rear muffler and 1 resonator pipe
Granted, my EGR valve is still going strong (as is my intake tube), so you've got me there
