ecuEdit MazdaSpeed3 ECU Read&Flash support + powerfull logger
Status
Not open for further replies.
get up to 600+ then well see. easy fix for you guys is just using extra injectors. i don't know or have not seen anyone run extra injectors yet, but i'm not a ms3 forum regular.
Okay, one more time. Anyone with a hot girl as their avatar needs to include a link to the full size photo in their sig. Are you listening JDM Sam?
i've been pushing this idea for years. there are those in the aftermarket who take any attempt to squash that notion illogically however as its not "their way" of doing things. i can tell you its in the works and it will work. and when it does, there isn't going to be a compelling argument against it.
whats the scoop here? i really just want it to flash my boost level. the old MBC works but is just a pain to tweek for the changes in weather all the time. i want something that will use the stock solenoid to hold it right where i want it. I WANT ONE !! any chance some testers are needed.
damn N00Bs
I can tell you this. Extra injectors will work just fine, as long as you can keep the supply line full of fuel. I have tried a similar test of this. I have run my wet nitrous kit with no nitrous.... So just fuel blasting in. With a tiny .016 jet in the nozzle i have watched my AFR drop 1.5 points. Extra injectors with a proper controller, maybe a boost activated switch would be nice.
I was doubting this was real, but now that I compare the pictured tables with ATR you can see it is actual data from the ms3. Very cool. The graphs look nice.
Subbed.
Always worth while to have a system that will let you diddle with your settings on the fly or on a dyno (get professional help tho).
Ive seen things like this before, usually work well.
As to the fuel issue, wouldn't it work just as well to upgrade the entire fuel delivery system, pump, lines (if needed) rail (also if needed, need to get someone with more tools and toys then me) and bigger injectors, then tell the computer whats what? This is what the Taurus owners group I used to belong to looked into. They put a bigger fuel pump, braided lines, bigger injectors on to the 3.0 twin cam motor and after a good dyno tune were able to squeeze out a significant chunk of power out of the motor. Dont ask me how much, its been...years since I was there (my 2003 SES Sport ate both cats, EGR valve, all 6 injectors and sparkys and damn near siezed the motor when fuel, ethanol, carbon, and GOD knows what else flash fried 500 miles from home....SNARL), but it wasnt too expensive.
Thats my hesitation with the AP and CP-E stanback, they are both too expensive for being locked into certain sets of stuff.
mazdaEdit Pro (for Professional tuners) is ready now.
Features:
1. mazdaEdit is separate tool based on ecuEdit functionality
2. Mazda Logger
3. Only OpenPort 2.0 is supported
Contact me for details.
I am closing this thread until the OP contacts Antoine about becoming an authorized vendor.
Status
