ok, so I have it installed but i'm 100% sure there is an exhaust leak as it has the sound you guys are describing and is obnoxiously loud, especially with your foot down in it and I think it's right at the spring bolts and here is a pic (it actually turned gold after heating up! is that normal for this? I cleaned it alright before installing, and after installing right before I started it up):
and here is what went down:
so after spending all morning messing with this thing (bruises and bleeding skin to prove it) I finally got the stock exhaust manifold off and realized just how very heavy that thing is! I didn't realize the weight savings. anyway, it was a fight the whole way through. anyway....
Just to be sure, I shot a tiny bit of PB blaster on the manifold bolts and a more hefty amount on the spring bolts (they were pretty rusted) and i let those sit till I could get the manifold bolts off and other things out of the way. Ended up having to fight this bracket holding the mid section of the stock mani on, so after removing that annoying bracket (first taking just the bolt off from the side thinking I could just slide the mani out from the side, that didn't work, so i had to go underneath and take out the entire bracket), mani bolts i went to work on the spring bolts. The one on the left side wasn't too difficult, I broke that loose by straddling the passenger side tire for leverage and using my foot to push the wrench and it came off in 3 pieces: the spring, nut, and washer. (i'm sure this was an interesting site: a guy holding onto dear life to a tire with a strained look on his face followed by an "ahhhh..." as the bolt clicked free and certain precious goods were crushed against the tire side wall..........). the other one 'seemed' to come off with little trouble too, untill i realized that on the second one (the right one) the entire stud came out, so I was holding 4 pieces: the whole stud, the spring, nut, and washer. At first I cursed the fact of rust existing, that was then followed by the realization of a possibly ruined day. I'm not sure if it's supposed to come completely off like that as nothing actually looked broken or stripped or anything, but it definitely seemed wrong. But back to this later...
I moved on to getting the rest of the stock parts out. I started to fight with the 6 nuts holding the top part of the mani onto the pre-cat. Once again they 'seemed' to come out just fine after cracking loose, but after taking off the top part i realized the gasket was in two pieces and i'm not sure if it was me that broke it or it was already in bad shape. So now I can pull out the rest of the assembly by just fishing it through the bottom. Yay! stock parts off and brand new shiny header to go in, I noticed the header gasket mating surface was dirty, really dirty acutally so I cleaned that off, slid on the new gasket (which didn't seem to be very cheap to me...), picked up the header to slide it in aaaaaaanndddd *clunk* it doesn't fit all the way down. Immediately I'm like "geez... all that work for nothing" so I tried different angles, more force and nothing, then I realized I could just take out the fan shroud with two little 10mm bolts, and it was just enough room to fit down *whew* So after successfully getting it in I get excited realizing I'm actually doing some cool work on my little P5 and I was proud of myself for a minute, until I started fighting with the midpipe, which has become the bane of my life right now! Also, the egr bung does not line up witht the egr pipe that is supposed to connect to it, the pipe sits about 1/2-3/4 inch back and will not swing forward enough to fit over the bung on the header, so i just blocked it off with a bolt for now until I can figure out something to do with that...(which will probably be nothing...) After feeding the header down I had to lift up the midpipe to get the one spring-bolt-stud that was still attached, to go through the bolt hole in the header, then I started playing around with the configurations of the spring bolts as I couldn't remember exactly how they went together. I wasted time doing that then after finally figuring out how they go back on I see that the hole for the second spring bolt (the right one) didn't nearly line up with the first hole (the left one)!! So I can slide through and tighten down the first bolt, but I can't insert the second one. So at this point I'm a little frustrated because I can't move or angle any pipe enough to make the holes line up, so after fighting with it for around an hour, I ended up just tightening down the one good side and just left the other side. I'm sure the leak is coming directly from that area from the uneven pressure on the midpipe from the spring bolt.
after getting home from work I re-tightened the bolts on the front of the header, as they were all loose and some not even finger tight. But while doing that I realized there wasn't a gasket between the midpipe and the header and was wondering if having that there (even with only one spring bolt) would fix the exhaust leak. But i took a quick look at Rockauto and I'm gonna go ahead and order a spring bolt set to fix the bad one (comes with the stud, spring, and nut). However, to actually fix the leak, I may have to take it somewhere to drill out a larger hole on the midpipe so the stud can actually go through!
Soooooo what I hope to accomplish very soon: get the midpipe drilled though, get the exhaust hardware and gasket to fix the leak (hopefully this will get rid of the ricey/leaky-exhaust sound..) after putting that on I should have a gasket on the header so it will mate nicely up to the midpipe, and a 'good' spring-bolt in place of the currently non-existent bad one, get the non-fouler and install it to rid one of the CELs, and maybe even get some header wrap as I'm still considering that too.
overall the actual work wasn't too bad, it was just those annoyances that ate up time, as I think i was out there for about 4 hours.......
