r1concepts
r1, have you ever heard or seen drilled discs crack? if so, is there a way to keep them from cracking?
Drilled rotors are more prone to crack and yes this a fact even if they are chamfered in. Now if you are tracking your vehicle I would definately use slotted only. Now for daily street driving, Drill rotors are fine. You will not put enough stress on it to crack. The drills are mainly for a better heat dissapation, to help with premature warping of the rotors.
