Finally got around to getting my car dyno'd after the atp bcd/mbc install. I always use the same dyno(dynojet) and the temp was 67degrees today. 65 degrees last time. Mods are cobb sri, txs racepipe, atp bcd/mbc @ 18psi.
Previous dyno (cobb sri, txs rp)- 266hp/280tq
Today's dyno (cobb sri, txs rp, mbc 18psi)- 273hp/293tq
Doesn't sound like a big gain...but the area between the two curves shows some gains of 20-25hp/tq in certain areas. I'm working on trying to get the file from the shop emaild to me as we speak. As soon as I get it, I'll post it up. A/F's were still rich. Under 11.5 by 4k under 11 after 5k. Maybe I have a boost leak...lol. Everyone else is running lean with boost @ 18psi. It would also explain the low peak numbers. Car runs good though....pulls hard. I'm going to try to re-ziptie everything and see if that makes a difference.
Let the number bashing begin...
