Getting dyno done this week on a dynojet. Any tips? What gear? DSC off? Fan on intercooler? Thanks in advance.
arent dyno jets inertia dynos? how would DSC have anything to do with the power the car is putting out?
Use the Search.
The ECU limits boost in the lower gears with the DSC on. 99% of people who have done this trick have seen a noticeable difference in boost/power.
Use the Search.
no diffrence in boost in any of the settings (all on, partial off, and all off) when the wheels are straight. confirmed with dashhawk i dont have the graphs anymore. psi diffrence between settings was negligable.
Ok did a couple more tests today using my DashHawk to capture the data. I did some tests the other day and it appeared that using the method of turning off the DSC/TCS really didn't net any boost. Actually these tests prove that our cars get more boost in 1st and 2nd than previously thought. Here is the outcome of my tests. I plan to do a few more, but I would really like to find a nice spot to do them without fear of Mr. Police Man.
Run 1 - DSC/TSC Off - 1st gear from a stop 8.70 Boost / 27.3 MPH / 5435 RPM -- 2nd Gear 15.95 / 46 / 5593 RPM
Run 2 - DSC/TSC ON - 1st gear from a stop 12.91 Boost / 27.3 MPH / 5627 RPM -- 2nd gear 15.95 / 46.6 / 5691 RPM
I'm not sure if I got the same first gear take off in Run 1 as I did in Run 2 as you can see the RPM's are a little lower, so the 1st run could have easly got up to more boost. Run 2 got a good 1st gear takeoff spinning the tires and turning on/activating TSC due to wheel spin.
Now due to inability to get the exact same runs you can take this information for what it is. Just a comparison using the DSC/TCS hack. To me it seems that on both of my tests (ones today and one the other day but no longer have the data from that one) you actually got a better boost in 1st than you did without TCS and DSC. But overall it seems that using the hack (for lack of a better term) does not really get you any gains and hurts your handling of the car.
My car has MS CAI, Epoxy Mount and I took it in for the updated flash with the latest Voluntary Recall and changed my oil with Royal Purple. These may or may not make my car act differently than others.
I'm pretty sure 5th gear is closer to 1:1 than 4th is.
Defend that statement. The goal of a dyno is to get as close to a 1:1 gear ratio to keep the dyno accurate. 5th is closer to 1:1 than 4th is. If the dyno can't handle the speeds at which 5th gear at 6700 rpm will generate, fine. You can't just say "4th for dyno is better" without having a reason for it.
Your statement remains entirely unsubstantiated save anecdotally. I'm starting to get the impression you don't really understand why this isn't very... compelling.
Depending on the way the dyno measures torque, you want to eliminate as much mechanical advantage from the tranny as possible. On dynos where torque is calculated by the rate of acceleration of a weighted drum (like Dynojets, I believe) you can get a run to read artificially high by taking advantage of gearing. This is why everyone suggests you use the gear closest to a 1:1 gear ratio. 4th is 1.171:1, and 5th is 1.085:1. Assuming you understand how ratios work, you'll notice 5th is closer to 1:1.
Now, on dynos that don't measure torque this way, you could conceivably run any gear you want to get accurate numbers, and there would be no issue trying to use a specific gear ratio.
I asked about 1:1 gear ratios because I wanted an informed answer, not your "BECAUSE" answer that tells me nothing beyond that you have strong and possibly misinformed opinions about this subject. If you can bring up anything specific, or some data or numbers or something, awesome. If you know something better about how dynos correct for gearing, or what effect the final drive ratios being different for 1st - 4th and 5th - 6th gears may have on trying to use the gear closest to 1:1, cool. I asked you to defend your statement, and you haven't.
If your only rebuttal is "Hey man I have dyno charts and my claim remains unsubstantiated, but I'll say it again anyway" you can keep it to yourself until someone who actually knows something about this can chime in.
our cars are geared differently depending on what gear you're in...our final drive ratio is 3.941 in 1st-4th gears, and 3.350 in 5th-6th gears. use 4th gear because it is the closest to 1:1 of the gears that have the better final drive gearing.
