melicha8 said:Just to clarify the above statement. Think of the flywheel as just a spinning mass. You go through the gears much faster in first and second than in the other higher gears. So...lets implement a classic physics equation Force=Mass*Acceleration. Take force to be the horsepower required to accellerate the flywheel. What happens when you decrease the mass by 1/2 which is what you essentially do with the fidanza. You get 1/2 the force required because Acceleration stays the same. That decrease in force required to accelerate the flywheel goes to the wheels instead. This is of course only under acceleration because force is only applied during any change in velocity(or in other words an accelleration or a decelleration)
God I'm such a nerd....
Um, this seems to have been passed up but I'm a little concerned. Why is your linkage popping out? Could this be an install problem?Equinox said:But anyhow, the problem I got now is, when I feather/dump the clutch from a race start, my shifter linkage will sometimes come out of it's rubber mounting point just behind the cat under the car.
slenser said:There will be less parasitic loss of HP to the wheels, which in case, will show an increase in rwhp on an inertia dyno and not on a load (eddy current) dyno.
You will have an increase in the engines ability to accelerate, but there is a loss of kinetic energy with the decreased flywheel weight. This means the aluminum flywheel will cause your engine to rev faster from a low RPM launch compared to an iron flywheel, but if you were to dump the clutch from a high RPM on a launch, the iron flywheel will help keep the motor in the upper RPM range compared to the aluminum flywheel.
The heavier the flywheel the more potential energy it has, with a heavier flywheel the engine will hit the tires with more power/torque because it carries more potential energy...it's like swinging a pail of water with one gallon, and trying to stop it, versus 5 gal of water.... with all other variables being the same the 5 gal will be much harder to stop and carries much more momentum.
So what does all this mean? If you want to drag, go with the iron flywheel. AutoX, aluminum.
If none of this makes sense....tough...It's 3:30 in the morning!![]()
Do you mean the iron flywheel will keep you in the powerband longer between shifts? Sure a lighter flywheel will make your rpm's drop quicker, but then just learn to shift faster.
A lightweight flywheel will help you go faster..whether it be for drag or autox. It helps your engine rev faster, and the quicker your rpm's rise, the quicker your speed rises. The only downside of a lighter fw is decreased drivability, and 9lbs is still heavy enough to retain drivability.
Minus said:ok so what is a good weight for a flywheel for day to day driving and occasional "fun sessions"
