p5sundevil
- 03.5 MidnightBlue p5
i saw a diagram about this on a site i was gonna buy my clutch/flywheel package from.
basically taking the number of 230lbs of savings in first gear with the 9lb flywheel in second gear it is about 1/4 to 1/3 of that and then in 3rd gear it is 1/4 of 2ng gears number and so forth to fourth gear being almost no gain and 5th none at all.
basically flywheels are for launches and gains in low end especially if you are boosted or heavily modded since most other mods move the power band up in the rpm and gear range and the flywheel helps in the opposite way. low gear.
