DVD double din Audio player
M2P503
2003 Mazda Protege5
Hey does any body know how to hook up a Double Din DVD/Audio player? I already have the audio / radio hooked up but the DVD player doesn't go on. What color wire is the DVD wire? Because its not labeled DVD wire . Where does the DVD wire get connected to? (squinty)
Wrong section, but anyway... There is no "DVD Wire", the unit is probably locked out due to restrictions on watching DVDs in vehicles unless the parking brake is engaged. There should be a wire that you have to connect to your vehicle harness that sends voltage when the parking brake is pulled. What brand and model DVD player are you installing? You can get little bypass circuits that you connect to the DVD player to bypass this restriction: http://microbypass.com/
Thanks man ill have to look into it
