Maxx Mazda
Contributor
- Stock P5
Basically, can the DSM AFC be used to control fuel trims while in vacuum? That way, I can do away with stalling without having to relocate my MAF. If I can tell the car how much fuel to get as soon as the car enters vacuum, it won't stall. Now, that being said, it will only modify the MAF voltage, correct? So if the MAF is stil lseeing a s*** ton of air (it's mounted just before my turbo) the AFC can only modify that signal, and I will still stall in theory, correct? I was looking at the PSC1 manual, and there is an alternative way of wiring it, so that instead of modifying MAF voltage, it connects directly to the ECU and will take manifold pressure, and output it as a raw value. If we can determine what the voltage values are for say 100%, 20%, etc. we can in effect remove the MAF completely and tel lthe stock ECU how much fuel to add based on the boost pressure sensed by the AFC.
Am I smokin crack here, or does someone follow me?
