MaydayDown_Joey
- 2002 Protege 5
Ok so the entire time I've had this car I've been plagued with issues. Mostly suspension issues.
One issues I've not been able to pin down is what appears to be a metal to metal squeak when turning the wheel, and slop in the suspension in this same location in acceleration or when other certain conditions are met.
- The squeak happens only when the car is on the ground, I tried it when it was in the air and nothing. I do not see the spring rotating or binding when I look and turn the wheel.
- The slop in the suspension manifests usually at low speeds (5mph or less) or if I go over rough patches in the road or very large pot holes and you can hear a noise when it settles or smacks the other side of the pothole. This also appears to be parallel with the direction. Another example is sometimes at real low speeds when I go to accelerate it feels like the slight delay on this side then the car (or power) lunges forward a little.
- Both have been there the entire time I have owned the car and the replaced parts lists below did not change either items.
- I also do not detect the any slop on the bearings. Nor do I hear any clunking in the axle (nor tearing on axle boots)
- A-arm ball joint are dry and torn boots, I see NO grease (this is a major clue for me)
Changed components:
- Shocks
- Shock tower hats and bearings
- Lower and upper spring rubber
- Steering tie rod ends (but not the arms)
- End links (connecting to sway bar)
- Front and rear motor mounts (they needed it)
So I'm considering replacing the lower a-arms, the whole car is pretty dry all the balljoints look shot and have torn boots, all 4 motor mounts were torn to one degree or another. So this might lead me to think that the a-arm bushings are shot (lateral instability) and the Balljoints are metal to metal (squeak)
Thoughts, suggestions, opinions?
Thanks!
Changed components:
- Shocks
Thanks!
