Driver Side Door broke. Looking for Door Manual
envy2
MY 36K/3 yr bumpber to bumpber warranty just ended and 1000 miles later the door switch(open/close) broke on the driver side. I doubt that I can get it replace free unless someone here knows how I get that done. Anyway I was thinking about fixing it myself. Anyone got the instruction on how to take it apart. I only see 1 screw inside that little pocket for trash. If someone who has the manual can send me a scan of that part it would be great so I can replace it myself. I check the mazdaspeed motorsports parts list and I don't understand how it's even tear apart to access the internal of the door. I don't want to start breaking off parts so any help would be appreciated. Thanks.
Thanks. I took it a part breaking a few parts along the way. Finally got to the lock mechanism and took it apart. The component for the lever for the manual lock seems to be broken somehow. Looks like I will a new lock since I still can't figure out why its not working and I'm not gonna tear down a good passenger side to find out why.
envy.. the door is easy to take apart and put back together.. a lot of it is just snap off/ snap back on. I ve taken mine apart like 3 times for speaker install, and sound deadening. pull and lift.. what part of the "switch" is broken? I remember that for a while my inside door handle had to be pulled all the way kind of hard to open and it was because one of the cables inside the panel was snagged. it will make sense when you open your door panel and see.
I have a bunch of interior parts if you need something. We stripped everything out of the car for the B-Spec build.
-Derrick
