I dont have a switch, theres a button on and offflip the switch to "door"
What about them? They work ok I guess?Check the micro switches on the door sill. Black little rubber nips
SC:derty_rabbit IG: derty_rabbit add me up
... the middle light does indeed have doors but I dont have a bulb there.
Gotcha, it is possible to rewire it so the front lights come on too? I got leds there and they light up the interior way better than the bulb.The middle light with the door switch is the only light that comes on when you open your door...
Go get a new bulb for it.
Sent from my SM-G950F using Tapatalk
U might be able to, but might take a good amount of tear down
Can I not pass a wire from the circuit and a wire from illumination to a XOR gate? If illumination is off doors do light up the leds but if illumination is on doors dont try to light up the leds.
Im not sure how to wire it all up though to be honest.
If this proves to be too much of a pain then ill just keep it the way it is.
Thats good to know, trying to figure out how to connect it to the circuit and keeping the option of on/off aswell.
I currebtly have ambient led lights that come on with headlights, wired to the radios illumination. Would love them to come on when a door opens too. Any suggestions on how I can keep them connected to illumination and controlled by dome lights? I understand that simply wiring it to the circuit while not disconnecting them from illumination will fry the circuit, correct?
