Sorry to post this up, Im completely stumped over this problem...
Ive used the search on here and google but found nothing relating to this.
So I hope you can help..
I have footwell led strips front and back, wired up to the dome light feed on the dash clocks wire harness plus the sills. All worked fine.
Until....
Friday, I removed my Lightup sills from the car to be re-done using El strips. Still all was fine untill I took the car out Sunday and noticed my front leds ( rears where disconnected) and dome light constantly lit ( doesn't fade or turn off) on the 'Door' function. The dome light turns off in the 'off' position BUT the leds dont?
Ive checked all the earth's, they are fine and the door pin switches, these are fine.
is the dome light dimmer function something that can go bad and be replaced?
What else could it be?
Ive looked at wiring diagrams but these might as well be in Hieroglyphics for all I can tell.......
Until....
