- 2007 Mazdaspeed 6 Sport
I only use Rotella T-Syn 5w-40 in my MS6. It's pretty cheap, but it also has shown over multiple oil analyses to hold its properties better than the Pennzoil, Mobil, Royal Purple, Amsoil counterparts. In the end, as long as you change the oil regularly and aren't using something ridiculous like straight 50 weight, you'll be okay under normal driving conditions.
By using an 87 octane in place of 91 or 93 (depending on year) it is much more likely that you will have issues with detonation and trigger the knock sensor. When the knock sensor detects detonation, it tells the ECU to reduce the amount of ignition timing that is advanced (lowering horsepower produced). By using regular, you will likely notice poor fuel economy. Additionally, you may also experience detonation causing damage to piston surfaces or bending/breaking connecting rods (although less likely).
