Questions:
Could be just Liqui Moly being better than that Castrol... and not having to do anything with weight. Maybe you should try Castrol 5w-20 to verify?
International Engine oil is spec'd differently than US spec Oil. Or is it North American spec oil?
Is US spec 0w-20 oil more similar to international 5w-20 oil than international 0w-20 oil?
Where is area 52?
5W-30 is fine too, as long as you don't experience cold winters:
But I don't see the advantage. The higher the viscosity, the greater the resistance to oil flow. Generally speaking, using higher viscosity oil decreases oil flow rate and increases oil pumping losses, and so provides less oil pressure to the points of lubrication. That's particularly a concern when the engine is started cold, which is when the most engine wear occurs. Plain bearings, such as the ones that support your crankshaft and camshaft, depend on oil pressure and flow rate to maintain film thickness. Another potential downside of higher viscosity oil is that it increases friction between lubricated surfaces that are moving past each other, e.g. a crankshaft spinning in a plain bearing. That increases shearing forces within the oil, which breaks down the oil faster.
They seem to have completely cured oil dilution with the 2017 diesel. At 2000 miles, mine hasn't moved. By 2000 miles on my 2016.5, it would have been well up the stick. The normal interval for gasoline and diesel models is 12500 miles in Europe.
This is something I've never understood why Mazda rev the engine high on a cold engine during start up, although it will only do it with in certain parameters, I was brought up to never rev a cold engine, to allow oil circulation.
Mazda say it for the cat to warm up quickly.
If you USE oil, you're way better off with 0w20.
If your oil level RAISES during OCI, then you've got to try 5w30.
See, with short trips the level goes up, not down. Because of fuel dilution. That's the nature of the beast.
Pretty much every one does this ime. All my Saabs did. My Volvos. Are there cars that don't?
I've read somewhere that note than 40 minutes drive "cures" the problem because it would generate enough heat to burn the particulate.They seem to have completely cured oil dilution with the 2017 diesel. At 2000 miles, mine hasn't moved. By 2000 miles on my 2016.5, it would have been well up the stick. The normal interval for gasoline and diesel models is 12500 miles in Europe.
I hope GJ never hears a cold-cranked BMW M3 from yester-year with the 4.4L V8. He'd probably pour straight 90wt gear oil in it!
That’s a 4L v8 - completely unrelated to the 4.4L.
That engine is specced for 10w60 except the rod bearing design was flawed from the factory so I would use 10w50 in the summer months. In the winter (if I even drive such A car in the winter) I would use 5w40 shell rotella, which is very easy on the engine during cold starts yet still provides engine protection.
Right you are, I was thinking of the M3 GT-S.
Interesting about the oil being so heavy...still not quiet.
The thing about the tolerances is nonsense, like I said earlier this engine has been recorded to use 5w30 with no issues. Cold weather starting proved to be not any harder on the engine when we used 0w20.
There is a BIG difference in terms of engine smoothness and how it sounds idling with the hood up. Its a very noticeable difference... you shouldnt just make assumptions about how it would sound, because you havent tried it yourself.
And again, .2 MPG difference. The figures would not change.
You are correct that oil/water cannot be compressed, but oil becomes thinner under high heat. Thicker oil has better resistance to shearing and becoming all watery.
It could just be that the engine is burning some oil so the level wont change.
So fuel dilution happens with gasoline engines as well?
Its to warm up the cat like you said.
Because of the 4-2-1 exhaust header design, the cat is not placed in the header which helps performance but affects emissions on cold starts. Ive never seen a vehicle that doesnt rev slightly high on cold starts to warm up the cat. You can code this feature out particularly if youre doing an ECU tune for a cat delete.
When you start the car in the mornings, just drive off right away. This will warm up the car quicker rather then just idling. The car runs rich in the mornings on cold starts which isnt healthy.
I just took a 7,500 mile trip across part of the US. It included lots of hot weather, freeway driving. 75 to 80 MPH, 90 degree driving across Missouri, Kansas, Colorado and Wyoming.. I did not see any visible difference on the dipstick after I got home. I was running 0-W20 Mazda oil. Regarding the engine running "smoother" with a different kind of oil, I assume you mean what you are hearing, rather than what you are feeling. After 50 years of driving I've never experienced an engine suddenly running smoother after an oil change. Just my $.02.
my 2014 cx5 owner's manual said 0W20 oil for USA and Canada; and 5W30 oil for Mexico. Why is that?
Does it mean 5W30 is the recommended oil for warm climate region such as Mexico?
