DIY immobilizer
meha11
ms3
After reading the thread about that fellas car being stolen i started to think about what could be done to stop that happening to me so naturally first i googled immobilizers and found this- http://autospeed.drive.com.au/A_107975/cms/article.html
i found the schematic hard to follow and ended up drawing it my self and made a couple of changes along the way. I just installed it on my jeep on sunday and am very happy with it, i may just install one on my MS3 also with some more changes.
Heres what i used.
1 4PDT industrial 12VDC relay with manual activation lever (valet mode)
1 red LED (optional;)
1 home security style magnetic switch
1 NC push button switch
1 magnet.
Total cost about $40.
basically all you do is use the relay to interrupt the cars vital circuits such as clutch switch, fuel pump relay, coil supply, ecu etc. The relay is energized by swiping the magnet across the hidden magnetic switch, you use a set of contacts to latch the coil in and BAM your done. The push button activates the immobilizer (break supply to the coil). I chose to break 2 circuits but obviously dont want to say exactly which ones for all to see.
The result is even with the key you can not start the jeep and i dont think anyone would even think about a hidden "sensor" that must be scanned to start the car. My hat is off to whoever conceived this brilliantly simple idea.
At first i tried to wire it up a circuit that was only energized when the ignition is on which would mean the switch isnt needed as it would automatically reset itself when the key is removed. This doesnt work because when to actually start the car you loose those circuits until you release the key and it springs back to the running position- damb the bad luck.
I put the magnet in my key ring- see pic. i also drew up an easy to read schematic for anyone who is interested.
This is very clever. I would suggest that you can find the power for the ignition which is not interrupted during starting, but is turned off with the key. This would eliminate the switch.
Yeh I'm not sure if such a thing exists but it is worth a try and a few hours of effort before the install on the 3
why do you even need this? the car already comes with an immobilizer! there is NO way to start the car without YOUR keys... it is VERY difficult to defeat/bypass it also... one will have to take a lot of time to rip a lot of s*** out under the dash to make it even start without the PATS key
Good point but read the first line on my original post again.
If you were to ask camerycev6 if he wished that for $40 his car would never have been stolen, what do you think his answer would be?
Many people here have other older cars too, i just thought i would spread the wealth a little thats all, i build stuff all the time because i like doing things like that, others may too.
