DG Motorsports CF A-Pillars
YayArea420
2003.5 Titanium Grey
Does anyone have these? If so how good do they fit? I bought the autometer single gauge pod and since it isn't the full pillar it is pretty ugly. I only want 1 gauge and this is the one I like the most.
How does your single gauge pod fit?
i don't like my full pillar (2) and was looking at the just two gauge holder not the whole A pillar
I don't really like how it fit and the pod is black and the pillar is grey. I got some interior paint to try and make it match but the paint I got ended up being more silver than grey. You can make it fit perfectly for sure but I couldn't get it to fit right because I was impatient and it was getting late.
i have a single pod on my pillar..and ive grown accustomed to it. only thing that sucks is that i had to drill holes into the oem apillar in order for the single gauge pod to hook up.
The instructions on the site says that you have to drill a hole in the stock a-pillar to feed the lines through. It also says that you have to clip the C/F one to the stock a pillar. Here is the install instructions.
I had these in my car for a while... I put them OVER the stock pillar covers. I just used the rubber trim to hold it in place. It was solid and easily/completely removable. They installed in like 10 seconds.
Thank you!!! Someone finally has a straight answer. How hard is it to drill the hole for the gauge?? Is the CF hard to cut through?
Well, it'll be a hole saw. I'm sure you can get a fine-toothed one at Home Depot or something
Yours didn't come drilled?
I haven't ordered it yet, but the site says that is doesn't come pre drilled. It would be great if it is pre drilled. I wanted to know if the fitment was good before I purchased them.
Fitment was great on the ones I had.
Now that I think about it I recall seeing them not drilled. :)
just ordered them today, i'll let ya know. I'm using this to replace the stock a-pillar ( i dont have the stock a-pillar) so i hope it fits!
they do not replace stock a pillar
they are a cover with 6 small holes that need to be drilled on stock a pillar to attach too!
there quality is excellent! amie and jason are good service people!
no cutting in cf is required!
I have the cf A-pillar on the passenger side since I have a dual gauge pod on the drivers' side. Fits good. Over top the stock pillar. Use double sided tape as well.
I just prdered a 3 gauge piller from crossoveer,is it a replacment?it's not the carbonfiber.
I needed to get rid of my single,because I needed room for boost,wideband,and oil pres
^^ that will be a replacement.
Now that I found out this goes over the stock piece, it looks like i'm gonna be cutting off the pods on my automemter, sanding it down, and attaching the CF to it. I dont really have another solution unless anyone wants to sell me their stocker...
