Riot_Polizei
Comp Engineering Student
- 2002 Mazda Protege5
...........about that IM you seek...................fresh untouched one on the workbench just waiting around for you...................
Sent an IM!
Super jealous man I'm glad the pro5 is still holding up. I look forward to what you do this year
Woohoo! The suspension stuff should be fun, looking forward to seeing it all go in and hearing how it goes!
The trailing arms reduce back/forwards play of the spindle and hub while also acting as a pivot arm perpendicular to the chassis.I've seen those and the Megan ones, but wasn't sure how much of an upgrade it was. What will it improve?
... That Charcoal canister was absolutely plugged with fuel, but even when left to dry, the evap system still wouldn't do its job.
...Just today, as if life was teasing me, I saw two very pretty Protege5s driving around...
Keep in mind that once you get your gas issue fixed, don't put more than 25-50 worth of gas in your tank after your pump handle clicks off.
I put a new gas tank on my car and I used to fill the tank to the bottom of the "F" on the gas gauge.
Now I can't get all the way to the top of the scale.
I'm thinking I could probably put a lot more gas in the tank but I'm not gonna risk it.
I still get lots of miles on a tank.
