Riot_Polizei
Comp Engineering Student
- 2002 Mazda Protege5
Hello Folks! I'm Riot Polizei, a college student in his twenties who seeks to document maintenance and upgrades here from time to time. Pleased to meet you! I look forward to many positive exchanges of information.
Not too long ago, my last car, a 91' 4WD Suzuki Sidekick, died. No matter how much part replacing or wrench turning I did, I couldn't save the ol girl :^(
More on the Zook here
RIP
I was fortunate, since the ashes of my Zook raised the (sunburst yellow) rose I now own.
Up from the ashes...
I was damn lucky. I picked it up at 119k miles with most of the needed service around this time already being done (most importantly the clutch). The paint is brand spanking new, the rims have minimal guttering damage, and it runs like a brand new car.
The transition from a offroader to a sportier, lower ride was somewhat jarring. Bumps began to matter, I could accelerate faster than a snail, and I could take corners at a thrilling pace! Aside from ride quality, I was shocked at how dialed in the gearbox felt. Compared to the somewhat floaty or boat-like Suzuki gearbox (in which you could somehow slide the gearshifter into BOTH 3rd and 5th at the same time...), there was little play. It felt great.
Upon really taking a shine to this car, I knew I wanted to do some fun things with this car. Not super fun things, since I don't have a lot of money to throw around, but simple things that'll either improve standard features or improve performance.
UPDATE (1/15/2018)
UPDATE (1/16/2018)
UPDATE (1/17/2018)
UPDATE (1/25/2018)
UPDATE (2/2/2018)
UPDATE (2/26/2018)
UPDATE (3/29/2018)
UPDATE (5/8/2018)
UPDATE (5/19/2018)
Update (6/3/2018)
Update (6/16/2018)
Update (6/29/2018)
Update (7/10/2018)
Update (7/13/2018)
Update (8/9/2018)
Update (8/21/2018)
Update (8/25/2018)
Update (9/1/2018)
Update (10/21/2018)
Update (1/26/2019)
Update (3/25/2019)
Update (3/26/2019)
Update (5/4/2019)
RIP
UPDATE (1/15/2018)
- "Fixed" fast windshield wiper fluid leak; removed list item
- Headlight functioning for now, ground appeared fine; removed list item
- Added crashbar inspection
UPDATE (1/16/2018)
- Replaced "Investigate mechanical groan/creak in tirewell areas" with "Replace front passenger-side tie rod ball joint and boot"
UPDATE (1/17/2018)
- Temporarily removed the HID upgrade from "modifications"
UPDATE (1/25/2018)
- Removed "Replace missing tirewell rivets and bolts"
- Removed "Inspect crashbar behind bumper and surrounding body frame"
- Removed "Investigate horn relay and/or replace horn"
- Removed "Short Ram Air Intake(?)"
- Added a "quick navigation" list of all major updates so far (and for ones to come)
UPDATE (2/2/2018)
- Removed "Do something about my pulsating brakes..."
- Changed "Replace front passenger-side tie rod ball joint and boot" to "Replace tie rods"
- Removed "Purchase adjustable endlinks"
- Added "Replace rear endlinks (fronts?)"
UPDATE (2/26/2018)
- Removed "Replace rear endlinks (fronts)?
- Updated "Install rear swaybar" to include " + rear ES endlinks"
UPDATE (3/29/2018)
- Removed "Buy a cat-back exhaust system"
- Added "Perform the Mazda6 "big brake" upgrade"
UPDATE (5/8/2018)
- Added "Replace driver-side front wheel bearing"
UPDATE (5/19/2018)
- Removed "Replace driver-side front wheel bearing"
- Removed "Replace tie rods"
- Removed "Eliminate rattle beneath CD player"--I tripped while entering my car and banged my knee into the center console. While it smarted, I realized that the weird rattles stopped. This happened about 2 weeks ago.
Update (6/3/2018)
- Added: Replace pulsating brakes
- Added: Fix E-brake cable(s?)
Update (6/16/2018)
- Removed: Replace pulsating brakes
- Perform the Mazda6 "big brake" upgrade
- Fix E-brake cable(s?)
Update (6/29/2018)
- Removed: Replace bashed-up lower grille
- Clean the engine bay, check vacuum lines for rotting/wear
Update (7/10/2018)
- Added: Install new radiator, fan shroud, and hoses
Update (7/13/2018)
- Removed: Install new radiator, fan shroud, and hoses
Update (8/9/2018)
- Added: "Replace entire pre-cat exhaust system"
Update (8/21/2018)
- Removed: Replace entire pre-cat exhaust system
- Added: Fix header->midpipe exhaust leak
Update (8/25/2018)
- Changed: Fix header->midpipe exhaust leak to "Fix resonator -> muffler leak"
Update (9/1/2018)
- Removed: Fix resonator -> muffler leak
Update (10/21/2018)
- Removed foreward regarding swaybar installation
- Removed: Install rear swaybar + rear ES endlinks
Update (1/26/2019)
- Removed color coding for importance
- Changed Modifications list to reflect projects to be completed relatively soon
- Removed: Re-finish black trimmings on the car
- Removed: Replace stone age center console relic with modern radio headunit
- Removed: Upgrade ignition wires
Update (3/25/2019)
- Removed: Begin VTCS removal
- Added: Install VTCS-less IM
- Added: Install MP3 ECU
Update (3/26/2019)
- Removed: Install VTCS-less IM
- Removed: Install MP3 ECU
Update (5/4/2019)
- Removed: Install Trailing Links
Update (9/7/2019)- Removed: "To Do" list--never used that anyways lol
Well, that about does it! Sometime later, I'll upload photos of the current state of things for elaboration.
I like tinkering, and I'm still learning a lot about the ins and outs of working on cars. Please feel free to give your input at anytime. I can't wait to get some wrenches turning!
Quick Navigation:
Post #1: Appraisals and Observations
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6564677&viewfull=1#post6564677
Post #2: The Headlight
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6564851&viewfull=1#post6564851
Post #3: CEL #1
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6566018&viewfull=1#post6566018
Post #4: Junkyard Treasure + The First Mod
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6567071&viewfull=1#post6567071
Post #5: Overspray Central (Or How I Inspected My Bumper)
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6567287&viewfull=1#post6567287
Post #6: The Rear Valence
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6567607&viewfull=1#post6567607
Post #7: February Status Report
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6568824&viewfull=1#post6568824
Post #8: The Second Mod
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6572727&viewfull=1#post6572727
Post #9: UPDATE: A Better Use for Tax Refund Money
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6573034&viewfull=1#post6573034
Post #10: Endlinks and Oil Leaks
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6574800&viewfull=1#post6574800
Post #11: Autocross
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6579721&viewfull=1#post6579721
Post #12: Cat-Back Exhaust!
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6581604&viewfull=1#post6581604
Post #13: The MP3 "Tune" + Seats
https://www.mazdas247.com/forum/showthread.php?123863154-The-College-Budget-P5&p=6585763&viewfull=1#post6585763
Post #14: CEL #2
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6588149&viewfull=1#post6588149
Post #15: More Ups and Downs
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6589143&viewfull=1#post6589143
Post #16: The Second Autocross
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6591338&viewfull=1#post6591338
Post #17: Sisyphus and the P5
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6593474&viewfull=1#post6593474
Post #18: Back in my hands; future plans
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6595689&viewfull=1#post6595689
Post #18: Little Update
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6596789&viewfull=1#post6596789
Post #19: Cause for concern
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6597499&viewfull=1#post6597499
Post #20: Crisis Averted; Minor Facelift
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6597629&viewfull=1#post6597629
Post #21: Wheels!
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6597706&viewfull=1#post6597706
Post #22: Server Maintenance Update: Cooling Problems
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6598209&viewfull=1#post6598209
Post #23: It's Okay!
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6598403&viewfull=1#post6598403
Post #24: A Temporary Hardline
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6598419&viewfull=1#post6598419
Post #25: Radiator Removal
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6598624&viewfull=1#post6598624
Post #26: Ready to Race!
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6599199&viewfull=1#post6599199
Post #27: Beginning Treament
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6600048&viewfull=1#post6600048
Post #28: BLACK
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6600540&viewfull=1#post6600540
Post #29: Approaching oil change round 2
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6601130&viewfull=1#post6601130
Post #30: Slightly Less BLACK
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6601826&viewfull=1#post6601826
Post #31: Plateaus, Clean Oil, and Exhaust Leaks
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6602159&viewfull=1#post6602159
Post #32: Multi-Point Exhaust Leak
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6602263&viewfull=1#post6602263
Post #33: Cost Analysis, CARB Rant
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6602390&viewfull=1#post6602390
Post #34: Parts Purchased So Far
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6602742&viewfull=1#post6602742
Post #35: bad Fix, bad Conditions
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6604734&viewfull=1#post6604734
Post #36: Hangers and Gaskets
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6605332&viewfull=1#post6605332
Post #37: Resumed Normality
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6606312&viewfull=1#post6606312
Post #38: All Patched Up
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6608151&viewfull=1#post6608151
Post #39: October: In With the Change
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6612943&viewfull=1#post6612943
Post #40: In For Good...
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6613143&viewfull=1#post6613143
Post #41: Mr. Gasket and the Future
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6613482&viewfull=1#post6613482
Post #42: CEL #3
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6624428&viewfull=1#post6624428
Post #43: Head Stud Nightmare
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6625351&viewfull=1#post6625351
Post #44: Trailing Arms
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6626975&viewfull=1#post6626975
Post #45: IM Upper-Half and Clips
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6628634&viewfull=1#post6628634
Post #46: VTCS Removal: Part 1
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6630102&viewfull=1#post6630102
Post #47: Swaybar, Part 2 | Intense Rattling
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6630944&viewfull=1#post6630944
Post #48: AutoX: Drivermod
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6631776&viewfull=1#post6631776
Post #49: CELs and Crazy Clunks
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6633220&viewfull=1#post6633220
Addendum
Post #50: VTCS Removal: Part 2
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6635136&viewfull=1#post6635136
Post #51: VTCS Removal: Part 3 (Plus Extras)
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6635885&viewfull=1#post6635885
Post #52: MP3 ECU + VTCS-less IM Installation
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6637391&viewfull=1#post6637391
Post #53: CEL #4
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6637646&viewfull=1#post6637646
Post #54: P0171: The Plan
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6638929&viewfull=1#post6638929
Development 1
Development 2
Resolution
Post #55: AWR Trailing Arms
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6642969&viewfull=1#post6642969
Post #55: Inactivity Status Report
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6645459&viewfull=1#post6645459
Post #56: Good News, Bad News
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6646179&viewfull=1#post6646179
Post #57: Junkyard Dive
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6646556&viewfull=1#post6646556
Post #58: 3rd Gear Grind, Worrisome Times
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6647003&viewfull=1#post6647003
Development 1
Development 2
Development 3
Development 4
Resolution
Post #59: New Noise, New Damage, New Parts Soon
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6649412&viewfull=1#post6649412
Post #60: The Search
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6650441&viewfull=1#post6650441
Post #61: Resurrection, Pt.1
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6657625&viewfull=1#post6657625
Post #62: Resurrection, Pt.2
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6659084&viewfull=1#post6659084
Post #63: The "Private Junkyard"
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6659916&viewfull=1#post6659916
Post #64: Suspension-Disbelief
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6660517&viewfull=1#post6660517
Post #65: Cleaning Up
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6660791&viewfull=1#post6660791
Post #66: Lowering Springs
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6662617&viewfull=1#post6662617
Post #67: Swaybar, Again
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6663361&viewfull=1#post6663361
Post #68: Inactivity Status Report
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6664895&viewfull=1#post6664895
Post #69: Phil Swift
https://www.mazdas247.com/forum/sho...ge-Budget-P5&p=6670711&viewfull=1#post6670711
