Default CPE FMIC Kit + SF... will they both fit?
dougefresh_
2006 MS6 wwp
EDIT: Ignore that default crap in the heading.. no clue why that is in there.
So, I need to know if any of you with the CPE FMIC are also using a SF and if they will both fit okay (barely is fine)?? lol I saw several cars with custom fmic's that were using a SF, and there was enough room. However, there is not much play in these to reroute, so I'd obviously like to know before I get in there.
I just want to know if you have the CPE fmic, if a SF will fit. The cpe pipes are rigid, so I'll go CAI if I absolutely have to. I'd rather cut my SF even shorter first, lol. If someone was able to cram a SF in with the CPE fmic, please let me know!
Thanks guys!!!
Well I found out the SF + CPE fmic both fit... here's a grainy pic to prove it, in case someone else wants to use this set up and is unsure:
