justanothermp5
Banned
- Rust Bucket
mechanic? why?
i doubt he would make it fit either, just do what that guy said, since it worked
mechanic? why?
Alright :/ i'll try my best, but wtf is goop?
Headlights, as hard as it is to put in regular bulbs. Fogs, cutting and drilling is required, but not hard at all.
What bulbs did you get? The H3C are recommended due to their shorter length whereas the H3's do have some issues. Can't recall anyone ever cutting and drilling before though?
Problem with H3C's are that hardly anyone carries them.
I installed my DDM Tuning HID kit tuesday night. So far so good.
I ordered 4500k bulbs and the optional battery harness. Install was pretty easy and straight forward but took me about 4 hours simply because I'm super anal. The only glitch I had was when hooking up the passenger bulb, apparently I had a plug in upside down, so it kept blowing fuses. Another once over from a friend cleared that problem up. Something so simple as flipping the socket was all it needed. They look great and pretty decent quality, especially for the price and the life time warrantee. I'm a happy customer.
The problem is that I'm not installing mine till sometime in March because I have inspection coming up. How do u open up the foglights though?
Once you get the lights off by removing the nuts that are holding them on (only 1 on each) and unplugging them, there are 2 screws in the back that hold glass lens on. Inside, you will see that the ground wire runs underneath a clip of sorts that grounds out the original bulb and also holds the bulb in place.
On another note, next time I do anything that isn't direct replacement, I will be taking tens of pictures. (rockon)
Finally installed the DDM slim 35w H4 4500k on my MP3. I thought they would be brighter.
pics before I order mine after the holidays....
