D2 racing coilovers
I have a set I bought used. They are pretty worn out now.
Very stiff spring rates, I am considering having the struts replaced.
rumored to be from the same factory in Korea
Its from TAIWAN. It was origin from England. But TAIWAN boss bought over. But its still good as before. I am using the track version. Front 12kg Rear 10kg. Good for track use. Not suitable for daily use. Unless the road is very smooth.
Street version has 7.5 kg in front and 4 kg in rear. You can order for eg. 9 kg in front..
My turbo diesel engine is very heavy and I need stiffer spring rate in front..
Mine is a stiff ride on 18x8 RX-8 rims and 215/ 35 series.
Makes you re-adjust your driving style to dodge the potholes.
Details please!
A friend just bought these.
