I've driven my CX7 several hundred miles now and I clearly have an excellent vehicle. I have found several things however that are annoying. I have difficulty in reading the tachometer and speedometer in sunlight. I find that I often turn on the parking lights so I get the dash lights on. The second and more important issue is the throttle tip-in from idle. I find it takes quite a bit of concentration to achieve a smooth take off at light or medium from idle. If I'm not very careful I find it very easy to jump to 3,000+ rpm in 1st gear when I wanted to have the auto shift at 2,000 or so to achieve a fairly slow acceleration. I don't know if this what I've heard about the TSB for "poor performance under 2000 RPM" COMMENTS Thank you. Ed
