The part no. of the power seat cable you need should be TK81-88-0D1 as mentioned by HyFlyer above:The broken short motor cable was the culprit with my power seat, unfortunately, I cannot find a part# or reference to replacing in any repair manual. Anyone have the part# or source to purchase?
For the broken short motor cable which isn’t available from Mazda, you can try several remedies posted here:The broken short motor cable was the culprit with my power seat, unfortunately, I cannot find a part# or reference to replacing in any repair manual. Anyone have the part# or source to purchase?
The drivers seat motor started screeching last week. Yesterday the cable (TK81-88-0D1)The part no. of the power seat cable you need should be TK81-88-0D1 as mentioned by HyFlyer above:
You can read the TSB 09-011/17 with part number listed and replacement instruction included here:
Power-seat noise
I bought this power seat cable a couple of years ago as a spare at my Mazda dealer and it was about $15 at the time!
PaulZooms, thanks for your response but that is the long cable that spans across the width of the seat adjuster frame. The short cable that is directly from the motor to the closest seat adjuster track is the one that I need. I am going to see if I can measure what's needed (+- 2" length) and have a machine shop make up for me.The drivers seat motor started screeching last week. Yesterday the cable (TK81-88-0D1)
was replaced and it resolved the issue.
$22 for the part, $51 for the labor and $9 for shop supplies. Mazda Extended Confidence service plan covered all but the supplies. First claim since Factory warranty expired 3.5 years and 33k miles ago. (69k total miles on my trusty GT).
Not sure I’ll break even on the extended warranty, but still have 3.5 years and 31k miles before it expires.
The replacement part you ordered won’t be the speedometer cable type like the original as you can see in post #6 in that thread by the OP. Instead, it will be a solid stainless rod / shaft and it’ll serve the same purpose stronger and better.⋯ I expect to be able to install the short cable when I receive.
No, Mazda doesn’t sell the short flexible steel braided cable for its power seat in the US. If it breaks, you need to get the whole seat bottom which’ll cost your hundreds. I have seen CX-5’s short flexible steel braided cable for sale in China. Unless somehow you can import it here, the $25 solid shaft is your only choice in the US.I think the original short cable is designed to fail in case the seat gets jammed on that side. If the replacement cable is a solid piece of stainless steel, it will not break if the seat gets jammed - something more expensive will fail, like the motor or the gear drive. Problem is I can't find the OEM short cable anywhere - does Mazda not make it available? If not, then may a curse be upon Mazda.
Nice find! Here’s another post for the same part from AliExpress:Update: I found a perfect flexible short (50 mm) shaft for $9 including shipping from China on AliExpress. It took only 11 days from order to delivery. See photo below.
The solid shaft sold on Amazon for $25 is a ripoff. At Home Depot, you can get 1/8" square key stock 12 inches long for $2 - enough to make 6 shafts.
Everbilt 1/8 in. x 12 in. Zinc Key Stock 800307 - The Home Depot
A square shaped solid metal bar, Crown Bolt's square bar is the alternative to the round bar stock. Typically used for framework, gym equipment and awnings. Available in various sizes and materials. Squarewww.homedepot.com
As I mentioned above, I think the solid shaft is a bad idea. If the seat jams, then the shaft will not break and something more expensive will fail, like the motor or the gear drive.
Hope this is helpful to someone.
Hey guys. The short cable/shaft is available on AliExpress.
2.95C$ 70% OFF|Casing Seat|seat Cushion Motor Drive Shaft - Flexible Front & Rear Seat Shaft With Flocking
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
I've just ordered it, hope it will fit. Ordered 50mm.
