2017~2025 CX-5 Pic Request: CorkSport Lowering Springs on Non-Turbo
Like the title says, I’m looking for photos of CorkSport springs on a non-turbo CX-5. I’ve read that because the NA engine is lighter, the front sits a little higher than it does on the Turbo models. I actually just picked up a set and am hoping for that slightly higher front-end look—if you’re running this setup, please drop a photo below!
Please share some pictures. Also what do you think of ride quality after the install?
Ride quality post-install: about 20% firmer if you install (correctly) adjustable sway bar end links, about 50% more firm if you don't.
