I'm a claims supervisor for auto (and other types of vehicles). Crawled under cars for about 17 years. Saw many many water related claims and repairs at many different shops in several states, not saying that to boast but to qualify my ability to help you. As one other guy indicated, if any brackish or salt water involved, you won't ever get it resolved. Assuming fresh, you might want to file a claim because gremlins may start to pop up for a good long while. One deductible. If you start tinkering and file a claim down the road, things will become much more difficult. If you don't want to file a claim: remove the engine air box. Remove filter. Remove lower resonator drain any water. Remove spark plugs. Run your starter to spray out any water that may have been ingested into the combustion chamber. Then change the oil and filter. Put plugs back in (good time to change them) After that, if all is well, your motor is probably fine, if it runs good. Interior: remove seats, lower trim, carpet. (Disconnect battery first). Remove any computer modules bolted to the floor and console area. Dry. Shampoo carpet. If seats are wet internally, they need to be broken down. Dry all electrical connectors. Remove front and rear bumpers and remove electronics, clean/dry connectors. Regrease connector pins with dielectric grease. Remove and drain headlights and dry indoors. Aim headlights. Remove brake pads and regrease hardware kits as needed. May need to rebuilt caliper pistons. Exhaust should clear itself out. Remove door trim panels and plastic internal covers clean and dry. Remove speakers for same reason. A lot of work to do it right. After all that, it's still going to be a crap shoot as far as if your hard work pays off and no issues later on.
