Can it be replaced? Can it not? What are your experiences?
There is a lot of information around (I've searched this forum religiously for the last 2 days), but there are not enough data to make a solid conclusion.
Yes, people have broken their RPCMs, yet others seem to have the LEDs working just fine.
If you have replaced your rear cargo light, could you please respond according to the following template:
While the plural of anecdote does not equal conclusive data, hopefully this thread can shake out some of the mysticism surrounding this lighting fixture.
- Year/Trim of CX-5
- Did you disconnect the car battery?
- Did you disconnect the wiring harness connecting the cargo light?
- What LED/bulb did you use (eBay/Cork/SuperBrightLEDs/VLEDs)?
- Did you have issues?
- How long has it been working properly for you?
- If removed/faulty, did you get the rear PCM replaced?
