Lets talk about how we can delete the Balance Shaft on the SkyActiv-G 2.5 .
The Balancer Unit weighs around 17 lbs and adds resistance to the motor. Removing so would free the motor from wasting energy rotating it twice the speed of the crank from idle to all throughout the RPM range.
Previous Experience with BS delete:
Difference between the Mazda 2.3 Balance Shaft and Skyactiv-g 2.5:
Compared to the SkyActiv-G 2.0 without Balance Shaft:
The Possible How:
I’m assuming both blocks (2.0 and 2.5) are very similar and maybe the oil pump parts are interchangeable on both motors. To delete the BS, we can probably do so by installing the 2.0 oil pump chain and tensioner after removing the Balancer Unit? Then obviously we would need to plug the deleted BS oil feed on the block. What will be a headache added is if the chain is not able to be disassembled to install/remove and needing to remove the crank/utility pulley etc..
Another option is if someone/vendor made a idle sprocket we can install in place of the balance shaft. Maybe something else to which we can take apart the BS case remove the balancers, put in the idler sprocket and install the unit/case back.
What you guys think ?
Back in 2003-2004 I removed the BS from my 2003 Nissan Sentra SE-R Spec V . I gained 5-6 MPG’s on the QR25DE motor (2.5L 4 cylinder). There was a little Power gain about 8-10 hp. In addition, it took about a qt more oil due to the extra space created when deleting the BS. There was ver so slight vibration around 3.5k RPM’s . And between 0-10 scale, I would say the vibration was around a 1-2 depending if you are very sensitive person.
From my observation, the 2.3 Balancer Unit can be removed simply by unbolting and dropping it. The Skyactiv-g 2.5 motor can not be deleted the same way. Unfortunately for us 2.5’ers , the Balance Shaft is Spun with a chain that is shared with the Oil Pump. See image below.
The 2.0 does not have Balancer Unit. It simply has a chain from the crank that spins the oil pump and chain tensioner. Image Below .
	The Possible How:
