Second attempt was also a fail (the camera didnt pick up the detail in the light well enough).
The best I can describe it is if you are <10 feet from a wall, turning and moving, the light shows on the wall, you can see the bulb center / points and as you turn it seems to bounce a bit left and right. They arent wild swings, and if not reflected on the wall, it is unlikely that it would be noticed. The garage I park in is a bit funky and there are 3 points at which I have this approach (10 ft from a wall with a turn) so I am thinking I am noticing it more than anyone else would.
Next I am near a mazda dealer I will pop in and talk to a tech and update the thread.
