- 2022 CX-5 Turbo
Strut tower bar i.e ultra racing
I had this strange vibration on my '16 Mazda6 GT.
I installed the strut bar, and it helps a bit.
Handling? I don't have scientific evidence. It does not feel worse. That, I can say.
What vibration was it (uhm)I had this strange vibration on my '16 Mazda6 GT.
A strut bar really isn’t going to do much for a car that is already structurally rigid. If you charge down a highway on-ramp at full speed you may feel a bit of a difference, but I think sway bars would be a More effective upgrade because it will reduce a lot of the body roll without affecting on-pavement handling.
Sway bars and strut tower bar are not the same bro. A strut tower bar is a chassis reinforcement item and a sway bar is a suspension item to reduce body roll by transfering force to the other side and also can limit suspension travel. Yes an stb could reduce body roll on an old chassis or one prone to flexing, but here it's mainly to reduce metal fatigue (over time you alignments can be affected by fatigue on shock tower), help maintain alignment during heavy weight transfer and possibly help during impacts. I'm glad I had one when i went onto a curb thursday because the camber adjusters on my coilover moved but I had no damage to my shocktower the bar, pr anyother part of my suspension. Just a surprising minor bend on one pf the wheels.
Starting off at an uphill slope.
Vibration from front-left side.
More prominent, the harder the acceleration.
Significantly better with strut bar, but still there.
Something wrong with yours. There was no vibration on mine during your described scenarios
Have you modified your 6 in any way such as different rims/tyres etc (uhm)
How about some keyfob covers? I got mine so I can tell which keyfob is for which car - but they also protect keys from scratches and drop impact.
https://photos.app.goo.gl/ob24BosVX6k39W8MA
I looked once for my 2019 but could not find any that accommodated the removable emergency key.
I've had a similar fob for my Lexus since 2013. Not once have I had a need to remove the key. I suppose if you ever needed to use it as a weapon, you'd be screwed if you had a case.![]()
I just ordered two of these in red to match the Soul Red on the car. They look great and get good reviews.
https://www.amazon.com/dp/ (commissions earned)
Here's a pic with the new cover. I just realized that the second fob they gave me, the one without the cover and the one that wasn't programmed correctly is missing the hatch button. Is that right, or did they just give me the wrong key?
