In what way are they better?I wonder if it is possible to upgrade existing backup camera to the upgraded camera that is in the new 2021 models? I have seen that they are much better than previous years.
I'm guessing it's about the bigger screen. I really only use it to make sure there's nothing directly behind me before starting to back up. The view out the rear window is pretty clear.Higher quality image and what seems to be a wider view. The latter may be due to the wider display screen.
I think you have to do the research to understand the resolution of the new 2021 camera and and the older camera and what limitations there may be on the older generation infotainment system we experineced in the 2014 CX5 GT and the 2016 Mazda6 Touring. My impression is that the 2021 infotainment is full HD, or at least higher res than the grainy pics from the older system.I wonder if it is possible to upgrade existing backup camera to the upgraded camera that is in the new 2021 models? I have seen that they are much better than previous years.
I'm just wondering if this particular camera (link below) would be compatible with my 2020 cx5?I think you have to do the research to understand the resolution of the new 2021 camera and and the older camera and what limitations there may be on the older generation infotainment system we experineced in the 2014 CX5 GT and the 2016 Mazda6 Touring. My impression is that the 2021 infotainment is full HD, or at least higher res than the grainy pics from the older system.
If you successfully swap the camera, you may find the head unit does not support my perceived impression of higher res.
That has a 1MP lens. You can't go any lower than that, so no chance the OEM is worse. Check your lens for scratches.I'm just wondering if this particular camera (link below) would be compatible with my 2020 cx5?
It seems to be an upgrade over my current camera.
https://www.amazon.com (commissions earned)
Does anyone know where to get these? I've been looking but I can't find any!The must have accessory for me are window visors, that was the first thing I got when I got the cx-5. I like the OEM ones because they're very slim and low profile.
The other must have for me, that's not OEM, is changing out the interior halogen lights to warm white LEDs. Luckily I was able to reuse them from my mazda 3. Another thing I carried over was the white LED for the license plate area![]()
He said they’re OEM window visors, Part #: KL2F-V3-700 (replaces KB7W-V3-700).Does anyone know where to get these? I've been looking but I can't find any!The must have accessory for me are window visors, that was the first thing I got when I got the cx-5. I like the OEM ones because they're very slim and low profile.
I might be weird but I bought aftermarket pedals and to me it made my pedals feel like they were too close. Floor liners and cargo tray are a must! and sun visors for the front windshield. I use them mostly for when i park somewhere sunny and i want to cover my infotainment screen.Just bought my 2017 CX-5 GS, and I didn't get any accessories. I do plan on buying genuine Mazda accessories soon.
My list to get includes
Floor Liners
Cargo Tray
Rear bumper pad
I'm thinking of getting the aluminum accelerator and brake pedal covers. Not the deal pedal, because I do believe the floor liners cover the dead pedal. Correct me if I am wrong!
Is there anything else you think is a "Must-have" for the '17 CX-5?
Thank you!He said they’re OEM window visors, Part #: KL2F-V3-700 (replaces KB7W-V3-700).
I have the OEM rubber mat as well. What I would like to see is a fold line in the mat, to match the one in the cubby-cover. This would make it much easier to access the cubby.Our Mazda OEM rear rubber mat also covers the cubbies, but has a fold line that allows you to fold up the hard cubby-cover, along with the mat 'corner', and store tall things like bottles etc there in the cubby. The mat puts some pressure against whatever you then put in the cubby and stops it rattling around. I'm sure it was just serendipitous, but it ends up being a very useful design![]()
Thank you!
Here's something I bought from an online place. It was about $15.
It really works pretty well, but if you want the most stable and level surface the steering wheel needs to be "upside down".
Where did you get them? Also can you post a pic of them installed?Same here. These convex mirrors usually are the 1st thing I buy after getting new vehicles.
$1 each.
Interesting but they appear to wide and do not fit right, leading to possible peeling up...But best of luck.I also bought this rubber rear bumper guard. It was only 8 bux!
I spent $7 on a package of adhesive pads. I used most of the package.
It completely covers the edge and while not a perfect fit the rubber seems thick and durable. The adhesive pads are removeable but very sticky.
I’ve seen these little convex mirrors at WalMart too many times. Get one and try.Where did you get them? Also can you post a pic of them installed?Same here. These convex mirrors usually are the 1st thing I buy after getting new vehicles.
$1 each.
It is very secure as I said I used almost the entire package of (160) sticky pads.Interesting but they appear to wide and do not fit right, leading to possible peeling up...But best of luck.
