Custom Performance Engineering's complete SPEED6 tuning solution
Question for the CP-E. After the dealer flashed my ECU with the new version my car loss power or better say it doesn't pull as before flashing. Will the PnP bring the life back to my car when using the standard tune from the PnP or no? My SPEED6 has no mods on. STOCK with K&N drop in filter. Thank you :)
Anyone feel free to correct me if Im wrong but Im pretty sure that the standbadck comes with a base map that will increase performance. One of the great things about the standback is that if you do not like the tune that comes with the system you can easily get "another map" from a fellow board member! There are various maps out there for stock and modded speeds as well as the ability to take your vehicle and have it tuned to your liking. (headbang)
a few questions for you??
which pid algorithm are you using??
what is your setpoint, feedback and output.
would a cascade controller not work better than a straight pid loop.
Im a control engineer and will help if i can
cheers
cheers
I kind of doubt they'd give that answer out publicly.
