- 2010 Mazda5 GT
I started a thread in the electronics forum last month regarding my HIDs. Basically, I had my driver's side headlight replaced under warranty because the projector lense had smudge marks on it causing the light beam to have shadows/dark spots on the road. The new headlight I got has the same issue (smudge marks that are more pronounced). Also in both headlights I have found specs of dirt/crumbs in them. I'm just curious to see if other members have unclean headlight units. The dirt/crumbs can been seen pretty easily if you just look down where the black plastic part is in the headlight, and the smudge marks can only be seen if you turn on your lights (HIDs or halogens). Wondering if you guys could check your lights to see if you have this issue when it's convenient and report back. The headlight that didn't get replaced also has slight smudge marks on the projector lense and dirt in it. I know some members could care less probably as this isn't a huge deal (if the light works, great, who cares
), but I'm just curious if this a prevalent thing with these headlights. Poor quality control at the assembly plant? Some pictures are below of the headlight that was replaced (will try and take some of the new one tonight):
Driver's Side Light output (you can see the shadow/ghost spot on the ground towards the middle. The dark spots toward the bottom are normal I think):
Passenger Side Light output (this projector lense has minimal smudge marks):
Both beams together:
