Crazy mod
st_riot
07 Black Mica Mazda 3i
Well on another mazda3 forum I showed my previous aviation themed mods. Here is the latest:
The stick is a Cougar Hotas joystick for flight simulators. It is a replica of the flight sticks used in F-16s, as well as other fighters. Although this has probably not been done often before, it may not be all that interesting, except that it is linked to this little monster:
And then mounted in my engine bay:
In the ABS cylinder is the motor from a Tokyo Marui P90 airsoft submachine gun. Before being integrated into my car, it was upgraded with some crap to take it from shooting at stock ~250(? I forget) feet per second to 350 fps, and while it isnt the most powerful airsoft gun, it still packs a powerful punch.
http://www.redwolfairsoft.com/redwolf/airsoft/ProductDetail?prodID=8926
So the main motor cylinder is mounted under the CAI, and the barrel extends to just barely behind the mesh of the open mouth grill, both using the stock airbox mounting points:
The big rectangle coming off the top is the regular capacity magazine, for reliability, with the mock bullets temporarily covered by some taped on plastic.
It probably doesnt need further explaining, but this 'weapons system' actually works!! Its wired to the trigger on the flight stick that is now my shifter, and the upper right rocker switch is a safety. The upper left button will link to a laser sight, but it hasnt arrived yet. The sight will be shrouded to avoid peripheral detection. Purely by chance, the line of fire is almost directly in line with the center of the steering wheel. It shoots as level as I could manage to align the barrel by eye, and the adjustable hopup gives it a backspin that will keep it on course further. It of course can fire in semi auto mode with a single pull of the trigger, or full auto by keeping it depressed. The magazine capacity is 68 rounds of 5mm BBs, usually .20 weight plastic, but metal BBs could be loaded. The plastic ones can most likely dent metal panels, easily break light bulbs, puncture several soda cans, sting like a b****, etc etc...
Here is a demo of the trigger:
http://smg.photobucket.com/albums/v604/spnkrx18ssm/?action=view&current=IMGP1110.flv
So there you have it, the first Mazda3 to be retrofitted with a small weapons system... :P
I did this 99% just for the sake of doing it. I realize arming a passenger car is not a great idea to begin with, and firing while driving is incalculably worse. Same goes for activating the laser sight. If anyone knows if this is explicitly illegal, please let me know. I doubt I will even keep it installed, as it is likely to break and inherently dangerous. I whole heartedly intend not to shoot at any person or vehicle, mostly because its pretty gay. I doubt it would be easy to detect, I would sooner be accused of holding a gun out the window and firing, but the threat of discovery still remains. Again, I am not an idiot and will not use this for evil. I realize that I am not piloting a military aircraft, nor am I a military pilot. It was made just for fun.
But it sure is cool 8)
Bond...........Jack Bond, 008. Not sure anyone would notice unless indeed you did shoot it at something other than animals blocking the road or clearing a path through a riot zone. Cops probably wouldn't even snap to what it was if they looked under the hood right at it otherwise. Sure would bewilder the inspection guy tho. Have fun with the laser site. Getting cats to chase it from miles around would be hilarious.
Now all you need is an oil slick deployer for the back :D
Pretty cool mod, but I'm not sure what (if any) uses it would ever have. I couldn't think of even 1 thing to shoot, unless you line some cans up and knock em down with your car/gun, haha.
that s*** is pretty gangster..lol anyone cuts you off...they just start hearing balls hitting the rear of the car...the joystick looks badass too, i bet people are like " wtf ". what else does the joystick control?
Wow, I could not have that because I would use that in road rage which occurs almost daily for me.
Wow, that is pretty original props to the idea other than that it would cause trouble for myself, deg a road rage item!
enjoy your jailtime if you ever choose to fire at someone on the road w/ that.
