Cracked Exhaust Manifold
jt644
2003 MAZDASPEED Protege
My stock Exhaust manofild is cracked and a factory replacement is $1700. Is this a common problem and does anyone know of any good aftermarket exhaust manifolds I gous get as a replacement?
I have found the SteedSpeed on StreetUnt. Where can you find the thunder ceramic?
The vendor for the Thunder(Protephile) posted he is no longer going to be on the forum. The best is to find a used thunder. The stock can be fixed, Make sure you get a welder that knows how to fix cast iron. Maybe pm him to see if he can order the V3 thunder before he signs off
Mine is cracked too. I'm just getting mine re-welded. If you want to go aftermarket I would go with the steedspeed.
