Darksun280
- MS3
sounds about rightlol at people claiming this turbo is good for 300whp. Personally based on trap speed alone my car is pushing more then 300.
the stock ic has a 3psi pressure loss. For me to run 18psi the turbo is spinning at 21 psi and its still giving me power. Correct? Add a simple ic that has a pressure loss of 1 psi and bump the boost up to 20psi, add fuel if needed. and this car will hit 115 traps, if not the manifold should get it there. 115 traps and a nice low 1.7 = 11s
