each flash cycle takes about 15 min and doing through the obdii port can be dangerous if there are any interruptions. Additionally the spec on the chipset used in MS6, MS3, and CX-7 ecus is only 100 flashes. It may last more but it's not spec'd to. Standback changes are instantaneous and can be changed/flashed thousands of times.
cp-e is devoted to the standback. Their flash will eventually fix things like weather related problems and closed loop/open loop transition but those things will only make the piggyback tuners that much more effective. Personally, with as many changes as I make to my car I like the flexibility of being able to tune it myself to the mods I make.
thats bs about the obdii port all other car/truck makes out the use the obdii port to flash / tune my tuck took 10 min each time the tuner had to edit the tune on my sct hand held tuner
we flew the guy into KC ( sal from psp) to tune & dyno 15 lightning/harley trucks
after he got done i had 2 tunes a tow and a power
if i need any othe help he could the email me a new tune and load it to my sct hand held unit
so why can't Cp-e give us a had held flasher cause they would stand to lose to much $$
it would also cost a good chunck of $$$ and time up front to make a hand held flashing unit
they could use a already made unit to load a flash onto
but licsenings fees to them would cut into the Ce-p's cash
