As some of you may know, I have been running the Greddy Emanage Ultimate on my 20B Cosmo with little to no success. Today however I managed to drive it for the first time without any major hick-ups.
Finding good info on the Emanage Ultimate and Rotary Engines is a real pain in the ass to say the least, yet alone trying to find info on how to run one in a JCESE Cosmo. Greddy really aren't much help at all and it is very annoying to see that they have advertised this unit as compatible on the 20B Cosmo even though I am clearly the first person (even outside Greddy) to give it a shot.
However, I have great assistance from Mitchel who works for Greddy Oceania. Greddy America though had really poor customer service but if anyone wants specific details then please contact me directly.
Okay so here is how to set the unit up!
Jumper Settings
All jumpers need to be left in the factory position. Contrary to popular belief the 20B does not use "Honda Pull-up Type Distributor." The ignition output signal is 5V not 12V (although I have tried both without any issues or damage)
The only jumper that needs to be changed is the airflow meter type. As it stands, the e-manage ultimate will not work with our standard 20B airflow meter. They have not implemented it correctly in software and you must not send this signal to the Emanage Ultimate, instead bypass this signal straight to the factory ECU.
A little note about the 20B air flow meter; it reads as if it where a hot wire meter, i.e. 5V is no load, 0V is full load. Although it seems like a hot wire signal, it isn't... there is something about the pulsing of its output that the Emanage can't handle.I am hoping that Greddy fix's this though.
Wiring Harness
The Greddy wiring diagram for the 20B-REW is WRONG! Later Japanese revisions of the manual seem to have fixed this, however Western kits still have the wrong wiring diagram.
The picture below shows the incorrect Greddy Diagram (Top) compared to the correct wiring diagram taken from the Apexi RSM Manual...
Note that pins; G, NE, E need to be moved one space to the right to correct the issue. AFAIK, this is the only mistake here, but it wouldn't surprise me if there where other problems.
If you are unlucky enough to have a harness made using this diagram then the symptoms are that as soon as you plug the emanage in to the car's loom, your injectors will start (without the car even being turned on) and will flood you engine MAJORLY.
The Emanage will also start up with an Amber light and then turn itself off after about five seconds. I emailed Greddy about this problem but they still haven't removed the incorrect diagram from their tech support sections of their website.
The other things that you may want to consider during the wiring is whether or not to use the water temp sensor. If you intend to use the auto-tune feature then you must wire this in instead of two knock sensors. I didn't bother with the inlet air temp.
Unit Set-Up
This is where we see more gremlins. I'll go through each tab separately...
Main setup.
Okay, once you have selected the 20B-REW you need to go to the # of cylinders tab and change that from R2 to R3.
RPM Signal Type should be "Ignition Signal"
Everything else remains the same.
Ignition Set-Up
This is another thing that Greddy stuffed up and is a bit weird to fix. Although the Cosmo 20B only uses two ignition signals, you need to tell the emanage to use four inputs and outputs (So long as you have followed the above wiring diagram).
For most vehciles, this automatically completes itself once you have selected the engine type... not so for the 20B.
Channel 1 needs to be set to Trailing and Channel 4 will need to be set to Leading on both maps. The fun part is that when you first try and set this up, it will force you to use the 13B-MSP ignition options. If you accidentally insert one of these then you need to delete the entire vehicle set-up file and start again...
So long as you get the Leading and Trailing in the right place, just hit apply, close the program and restart it, the changes you made should look like my window above. Once again, I'm hoping that someone at Greddy reads this and makes changes to the program as they seem unable to read emails from customers.
Okay, these are two main panels that you will need to change. I won't go into the other just yet but so long as you have not selected any maps, the car should be fine to start and drive. At this point it is time to take it to a Dyno and check those AFR's. For ease, I have attached my datalogs and E-manage file for those of you brave (or stupid) enough to take the plunge with me.
Jumper Settings
Wiring Harness
Unit Set-Up
Main setup.
Ignition Set-Up
