Nope, Durham, NC (USA)Fai said:Hey EnjoyMinuteMaid do you live in Durham Ontario?
mdaj said:Not loud for me IMO. Great no matter what..
EnjoyMinuteMaid said:it really is loud man, if you wanna buy mine i'd probably sell it too you for a lot less than 389+shipping...pm me if your interested. Plus I live in Durham, don't know how far that is from you...
Speedplease said:no what you do is get an MIL eliminator kit or make one yourself. After you install this on your o2 sensor, you need to take off the little heat shield on your down pipe. After this locate the bolt on the right side of your down pipe. its on the right side if you laying under the car with your legs toward the front bumber. take out the bolt/plug and insert the o2 sensor into the down pipe tighten and your done. And just zip tie the o2 wire out of the way of anything.
Speedplease said:Yes read my post above i tell you where to put your o2 sensor. it goes right in the downpipe. the down pipe is the pipe that comes off of the s pipe. its the pipe you hook the first pipe of the exhaust up to the one you have to use the spring bolts for.
