FYI, these are on back order from corksport. i ordered mine then got the email, lol...
ohhhh...something to think about: some people have complained about squeaking coming from the insert later on after a while. i think this may be caused by the insert rubbing against the the rubber, so i ended up greasing the insert (the inside portion) with some mobil 1 synthetic engine grease to make sure this doesn't happen. i don't know if i'm being too paranoid here, but i'm pretty darn sure i'm not hurting anything by doing this...=d
I think lubing it would be exactly the opposite of what should be done. If mine starts squeaking, I'm going to pull it out and glue the pieces together. That should stiffen the whole thing up nicely. Make it more like a one piece unit.
umm.. anyone got some more pics of the install process i would greatly apreciate it (yes)
Hey - I'd like to thank Sacrilicious for the post on the bracket. I took his advice and had the thing in there in about 5 minutes.
If you buy these inserts, go this route!!!!!
