- All Mazdas!
The common problem of coolant tank failures has gone too far. Leaks, drips, and holes are not something we will stand for. So what is the solution? The CorkSport 2010-2013 Mazdaspeed 3 and Mazda 3 2.5L Coolant Tank Reservoir!
The CorkSport Coolant Tank Reservoir is made of a durable aluminum to prevent the leaks that can plague so many stock coolant tanks. We realized quickly though that without X-ray vision it was hard to tell when to top up your coolant, so we implemented a sight glass. Thanks to this sight glass you can easily spy low coolant levels and top up. We also included a high-pressure cap for increased performance and style.
The CorkSport 2010-2013 Mazdaspeed 3 and Mazda 3 2.5L Coolant tank requires no drilling and is a bolt-in replacement that wont discolor over time. The Coolant tank is black to keep an OEM look in your engine bay, though it could be easily modified with decals or painting. With every CorkSport Coolant Tank getting pressure tested before it leaves our door, you can have peace of mind that you wont have any more coolant tank leaks.
The Mazda Coolant Tank Reservoir is now available for sale and priced at $149.99.
Learn more about this product, or purchase it, here: http://www.corksport.com/corksport-mazdaspeed-3-coolant-tank-reservoir.html
