corksport dp hardware/gastkets
cjms3
hey guys i just bought a used dp, and llow and behold no hardware. can i just use the stock hardware? is there any gasket i need? if so can i use the stock gasket? thanks
You'll need two bolts, washers and nuts for the cat-back part of the install, and you'll need donut gaskets.
On my TurboXS I was able to use my stock donut and TXS supplied flange/gasket for a tight fit....I did use new bolts/nuts/washers for the CBE connection. Don't know whether it will work with the CS design?
There's donut gasket on the stock CBE section where it connects to the stock midpipe. I removed that one and installed it on my TurboXS midpipe/racepipe section. Like I said I had a flange fitting (from TXS) too that the donut fit into then attached to the stock CBE. I had no leaks when running this set up...
go to corksport.com and call them. they will have no problem telling you what you need and where to get it. and the donut on the dp it sold my them. just call and talk to chris. he is very helpful.
