CorkSport CX-5 Axleback Exhaust stock
We just picked up a new AWD dyno, there is a shopping list of things we need to run across it. The axleback and combos of it with the intake will be done in the future.
On 2wd Mazda 6 turbos the axleback was good for ~6-7 hp.
-Derrick
Looks like the CX-5 axle back exhaust weighs around 23-24lbs. Will be a couple weeks b4 I uave time to install it. Once I do I will weigh the stock exhaust to see what the difference is. Every little bit of reduced weight helps.
I was thinking there was a extension between the muffler and the factory. Closer inspection suggests I was incorrect. Sorry.
Hey guys, I finally pulled the trigger - I should’ve got the exhaust earlier! 😎
